HF 4-1/2" ANGLE GRINDER - ITEM 95578
  • bigdaddyjohn
    • 129
    • Fort Wayne, IN.
    • Jet 10" Contractor
    Not bad for under $9. Here's the bottom line. I need to cut "T-Posts" that are buried underground in three feet of concrete. (Can you say overkill?)
    Out to local HF to see what I can come up with. Found it onsale. This version comes with no wheels does have the flange washers and a spanner wrench . All you have to do is add cutoff or grinder wheel. For a few dollars more, I found a ten pack of metal cutoff wheels. Two bucks for safety glasses. For $21 with tax, I was able to quickly cut the T-Posts. Less than a minute to eat through.
    Say what you will about HF tools. I certainly got my money's worth and them some. Is it pretty and have the DeWalt name? Nope. It's a blue DrillMaster with a reversible handle. Spins the cutoff wheel at 11,000 rpm. Just let the wheel do the work and it will treat you right. No complaints with this one.
    Here's the link: http://www.harborfreight.com/cpi/cta...emnumber=95578
    Yes
    59.07%
    114
    No
    3.63%
    7
    Only if I can see the item in person a select it myself
    34.72%
    67
    No way. I value my money too much to experiment
    2.59%
    5
