I want to make an espresso tamper for my wife that will involved making a knob app 2" in diameter by 2.5" long. Recently I saw an article in a wood working magazine that had people without a lathe turning a similar knob using a drillpress and rasp and files. My concern with that procedure would be the side load on the drill press. My fist thought was to make some sort of live center to support the bottom of the turning but I am also wondering if a simple rod in a hole would work.
Another complication is that it will probably take several test pieces in cheap wood before I move to the hardwood. I haven't decided what wood I am going to use yet. Possibilities are Cherry, Hickory and Oak.
So, do you think I maight ruin my DP? Or can I pull this off if I rough cut the blanks to close to the fininshed shape before going to the rasps, files, and sandpaper while supprting the lower end.
Thanks for your time
Bob
Bob
I have seen where a nail was used for a tail center and a lag bolt for the drive center.
(padauk and maple):
