Raising burr on scrapers
  • gerti
    • 2233
    • Minnetonka, MN, USA.
    • BT3100 "Frankensaw"
    I am having a hard time raising a nice burr on my round nose scraper. I have a Crown burnisher (polished HSS). My problem is controlling the burnisher, it is just so 'slippery'. Any tricks to it?
    I am considering building a jig where the burnisher sticks out or a board at the right angle. That way I could just have the scraper flat on the board and use both hands to guide it against the burnisher.
    Gerd
  • kwgeorge
    • 1419
    • Alvin, TX, USA.
    The bur that is created during sharpening on the grinder should be sufficient. Generally when I create a bur on a cabinet scraper it is necessary to use steel that is harder then the steel you are creating the bur on. I have an old square screw driver that works nicely for this. Veritas out of Canada makes a little jig for putting a bur on scrapers and it is available at Woodcraft.
    You want to be careful with a bur on a turning scraper though, too much and the tool becomes grabby and difficult to control. Personally I will only raise a bur on a turning scraper if I am trying to remove a lot of wood and I need the tool to be more aggressive than normal. Otherwise I always knock the bur off with a diamond hone right after grinding as I tend to use scraper more for inside work for a finish cut.
    • gerti
      • 2233
      Thanks Ken, I'll experiment and observe how the tool handles under the various conditions.
      Gerd
