Help on Turning Acrylic Pen.
  • MBG
    • Apr 2003
    • 945
    • Chicago, Illinois.
    I don't have a lot of experience at the lathe - made 6 pencils/pens from wood about a year ago. I have a Rockler flattop pen kit that I was going to make for my 11 year old and he chose an acrylic material.
    Any suggestions on what speed to run the drill press and lathe.
    (I must confess - I think I have cracked one of the pen blanks during the drilling process.)
  • mudder
    • 1532
    • I live in a house
    • Delta 36-650
    Acrylic needs a good SHARP bit fed slowly and cleared often. Did I mention the bit must be really sharp. I use water to keep my VERY SHARP bit cool. I drill about an eigth of an inck and withdraw the bit completely to clear it. Proceed slowly at the end or a blowout will happen even with SHARP bits. Turning is like with wood, I turn around 2200-2500 rpm I switch to wetsanding at 320 and wetsand to 600 and then I switch to MM (micro mesh) to get it smooth and shiny. remember to use a good sharp bit and be cautious.
    here is my last acrylic:
    http://www.bt3central.com/forum/topi...TOPIC_ID=17687
    Hope this helps.
    • MBG
      • Apr 2003
      • 945
      Thanks for the help Mudder. I turned the blank last night and it looks great! I was surprised how much longer it took to turn the acrylic than wood.
      I was worried about the finish but I progressed through abrasives through 1500 grit automobile wet sand paper. Then I used Scratch/Swirl Remover by TurtleWax (I also use this stuff to remove scratches from CD's/DVD's) and finally a liquid auto polish. The finish looks like glass.
