Woodturning class/Hook tool
  • gerti
    • 2233
    • Minnetonka, MN, USA.
    • BT3100 "Frankensaw"
    Monday I had the pleasure of attending a woodturning class taught by no other than Alan Lacer. It was a lot of fun, and I learned many things.
    My favorite though was the hook tool. These tools are widespread in Japan and Scandinavia, though relatively unknown here (other than it's easier to manufacture cousin, the ring tool, which is somewhat harder to use and sharpen).
    Anyway the hook tools are specially suited for finishing cuts on hollowed end-grain, such as in a box. Though I am not a very experienced turner, I found it was very intuitive to use and I was immediately able to produce a shiny surface on poplar end-grain! Alan makes those tools himself, and apparently it isn't all that hard, Check it out, just enter "Alan Lacer Hook Tool" in google and you'll find plenty of info.
    Gerd
  • WillR
    • 32
    • Bradford, ON, Canada.
    Gerd
    I pulled the instructions for "The Hook" -- I will try to make one as soon as I can find a blinking supllier of the tool steel blanks in the north of the GTA (Toronto Ontario).
    Busy Bee tools has blanks -- but they are the short ones otherwise I guess it is the Enco blanks...
    Here is the Enco link for the blanks...
    go to
    CUTTING TOOLS TOOL BITS RECTANGULAR
    http://www.use-enco.com/CGI/INLMK3?PMK0NO=418287
    For example
    Model #383-5754
    1/4 X 1 X 6 M-2 RECTANGULAR TOOL
    Turn a handle, Grind the blank - as appropriate and voila!
    Will R.
    http://woodwork.pmccl.com
    • WillR
      • 32
      Gerd
      One more piece of info...
      http://www.aroundthewoods.com/hooktool.shtml
      Darrell's site has a lot of good info for turners...
      He was the one that pointed me to Enco and Busy Bee for Tools steel.
      http://busybeetools.com/
      The follow the More... option to
      Cutting Tools >> Tool Bits HSS
      Although at Busy Bee only this one seems to be long enough -- possibly -- for lathe tools...
      Item No: 160130
      Precision Ground Tool Bits - 1/2" x 4"
      Fine Quality high speed steel holds a keep edge for super results
      Will R.
      • jl
        • 91
        • Nova Scotia, Canada.
        Will:
        Two other places to get tool steel are:
        - Ackland Grainger - www.acklandgrainger.com
        Precision ground oil hardening flat stock - 18" length
        - Metal SuperMarket - http://metalsupermarkets.com/
        I'ld be interested in seeing the finished tool.
        Jean-Luc
        • Mort
          • 311
          • Ellenton, FL - winter, USA.
          The Club made the hook tool last year from Enco oil quenched round bar stock. They work amazing well. Can be a bit of a challenge to get and keep sharp without a Dremel. As Gerti said they are great for finishing cuts on boxes.
          Even a blind hog finds an acorn from time to time.
          • WillR
            • 32
            quote:Originally posted by jl
            Will:
            - Ackland Grainger - www.acklandsgrainger.com
            note fix on Acklands web site...
            Acklands --$40 a piece cobalt steel only... Not that helpful either - run like a MacBurger place...
            Metal Supermarkets - will have tools steel in April. Called them - none is stock - says it is a chain wide issue. helpful - but no got...
            So - Busy bee or Enco only still.
            Thank you for the effort though...
            Probably will buy a piece or two from BB and try tool making - then get proper stuff from from Metal Mart next month or place an Enco order...
            Will R.
