help with Jet mini?
  • oakleydo
    • 37
    • KS.
    help with Jet mini?
    I turned on my Jet mini lathe the other day and the motor would run but not the belt. I loosened the bolt on the motor and pushed down which tightened the belt and got it to work, however, every time I turn it on now, I have to do the same thing. Anyone have any ideas?
    I'd call Jet. Tyey will probably send you a new belt.
    Meanwhile, try cleaning the belt real good.
    HTH,
    Ken
    • Scottydont
      • 2359
      • Edmonds, WA, USA.
      • Delta Industrial Hybrid
      Sounds like it needs a new belt. Try posting over at www.penturners.org there are lots of Jet mini owners over there.
      Scott
      Edmonds WA
      No coffee, no worky!
      • kwgeorge
        • 1419
        • Alvin, TX, USA.
        I would check the pulleys and make sure they are clean and not slipping. I would also check the belt for wear. Next make sure your motor is staying locked in the position that you have set it in.
        Jet will send you a new belt with no issue. The contact info is;
        http://www.wmhtoolgroup.com
