First 'Hollow Vessel' Attempt
    My first weak attempt at a hollow vessel. It [u]was</u> supposed to be bigger, but a couple of 'design changes' resulted in about 3" in height. The inside shape does indeed follow the outside, with the wall being about 3/16" thick. I used a round end scraper with the left side ground, followed by a Sorby Hollowing tool.
    This is a piece of Sourwood from the 'fire wood' pile. I sanded through 320 with paper and through 12k with micromesh. Finish is Crystal Coat after sanding sealer.
    I think these are going to be a fun challenge.
    ken
  • mudder
    • 1532
    • I live in a house
    • Delta 36-650
    Uhhhhhh,
    For your "first" attempt I applaud you!
    Wish I could show you my "first" attempt, or my "second" or even the "third" attempt. Maybe for me my "fourth" attempt will be the charm.
    Good work Ken.
    Mudder
    • Chuck C
      • 430
      • USA.
      Nice looking vessel Ken, its nice to get a piece off the scrap pile and not have to put it back on, like I tend to do. What is the actual size?
      Chuck C
      If the skipper heard you call that deck a floor he would throw you through that little round window
      • Ken Weaver
        • 2417
        • Clemson, SC, USA
        • Rigid TS3650
        "Weak" attempt? Looks pretty good to me Ken! Better than my attempt at drawer joinery yesterday!!
        Ken Weaver
        Clemson, SC
        • kwgeorge
          • 1419
          • Alvin, TX, USA.
          I also think is look good and you did a fine job.
          • gerti
            • 2233
            • Minnetonka, MN, USA.
            • BT3100 "Frankensaw"
            Tzz... My last attempt is probably still in orbit... But then I am a sport-turner: catch and release...
            Gerd
            • GeekMom
              • 752
              • Bonney Lake, WA.
              • Shopsmith Mark V
              Nice shape - definitely nothing to be ashamed of! Good job, Ken.
              Karen
              • boblon
                • 727
                • Florida, USA.
                Yep, I'd say you done good. I like turning hollow projects. They are more challenging, but I find them much more interesting when they are done.
                BobL.
                • Mort
                  • 311
                  • Ellenton, FL - winter, USA.
                  Very nice. My first try made some very large napkin rings.
                  Even a blind hog finds an acorn from time to time.
                    Nice work. Can't wait to see subsequent attempts.
                    • Scottydont
                      • 2359
                      • Edmonds, WA, USA.
                      • Delta Industrial Hybrid
                      Nice work Ken. My first attempt ended in a blowout that resulted in a dent in my shop wall (better it than me!) Needless to say I moved my lathe away from the shop window.
                      Keep at it!
                      Scott
                      Edmonds WA
                      No coffee, no worky!
                        Nice work Ken. If that is your first attempt then it looks like you may have mastered that Jet.
                          Thanks again folks.
                          Chuck, it is right at 2 3/8" high, 2 3/8 wide at the largest part, 1" at the bottom and the opening is 1 1/8 dia.
                          ken
