Drill Chuck
  • Denco
    • 426
    • Coming soon: California
    Drill Chuck
    I've been practicing making boxes. The boxes aren't all that great yet, but I'm getting there. After reading Ken's tutorials and such, I'm thinking of getting a drill chuck and using forstner bits to hollow out the boxes. I've been using forstner bits in my drill press, but I get off-center once in awhile and that hasn't been fun when it happens.
    I've worked on hollowing out the centers with various gouges, but I'm starting to think I'd like to get more experience turning before I start that up again. (i.e., I'm impatient and want it to be perfect NOW [)]). The rest of the box turning process has been really enjoyable.
    Anyone know of a resonably priced drill chuck that you'd recommend?
    I use #2MT and I'd like to get 1/2" chuck. Should I buy it as one piece or buy a #2MT arbor and then just get a Jacobs chuck at the BORG? I'd prefer to use keyless.
    Your thoughts?
    *****Measure twice, cut once.....rats, back to the lumber yard.*****
  • RayintheUK
    • 1792
    I'd steer away from keyless on a lathe - I like to know that I can undo the chuck if it gets wound up really tight by a jam or for any other reason. I get the feeling that a keyless would be a real pain to undo if something similar happened. JMTQW
    Ray.
    Did I offend you? Click here.
    • kwgeorge
      • 1419
      • Alvin, TX, USA.
      I bought a couple of the ones Harbor Freight has and they work pretty well at $9.99.
      • Denco
        • 426
        Thanks, Ken, for the advice. Very much appreciated.--Den
        • mmcduffie
          • 146
          • Des Moines, Washington.
          My Sears floor drill press uses a MT2 chuck. I just knock it out to use in the lathe.
          Michael
          Des Moines, WA
            I use the Woodcraft #142553 chuck and am happy with it.
            • foneman
              • 235
              • kansas, USA.
              George,
              Did you drill and tap the end of the MT2 so you can put a piece of threaded rod in it long enough to put a nut and washer on it so it doesn't work loose? I picked up one of the HF chucks and haven't used it yet.
              Thanks
              john
              • kwgeorge
                • 1419
                • Alvin, TX, USA.
                No, I have not used a draw bar with mine yet. I have a collet chuck so I don’t use the Jacobs for that purpose. It is a good idea to use a drawbar anytime you are using any accessory mounted on a Morse taper though.
