A New Bottle Stopper and A Question
    Here is one I turned today. It's mahogany with Myland's sanding sealer and Behaland's turners finish.
    The question is: Why does the kit require a 6mm bit when the mandrel is 1/4 20, OK the 1/4 20 mandrel screws into the 6mm hole, and the threaded post on the stopper is slightly under 6mm. You are supposed to screw the threaded post into the drilled hole. A -6mm post does not screw into a 1/4" hole, we have a bit of slop here. Have any of you run into this and how have you solved it?
  • Scottydont
    • 2359
    • Edmonds, WA, USA.
    • Delta Industrial Hybrid
    I ran into that too Dick. I had been gluing them onto the threads with CA glue. I was thinking of taking a threaded bolt the same size as the stopper threads and just putting it in a MT2 drill chuck. I got my mandrel at Woodcraft. I am assuming you did the same Dick?
    Nice stopper by the way!
    Scott
    Edmonds WA
    No coffee, no worky!
    • gerti
      • 2233
      • Minnetonka, MN, USA.
      • BT3100 "Frankensaw"
      My problem: I can never get the turned wood of the mandrel. Even used wax on the threads last time didn't help.
      Gerd
        Scott
        My thoughts exactly. I was thinking of dropping down to a 5mm bit and using a bolt the same size as the threads on the stopper as a mandrel. I don't know why Woodcraft sells an oversize mandrel, they didn't know either.
        It sure is nice to have a forum like this where we can kick things around and come up with answers and solutions and sometimes even an I don't have a clue.
        Gerd
        I don't understand why there would be a problem screwing the stopper off of the mandrel. Are you using CA on the threads when you screw it on?
        • gerti
          • 2233
          quote:Originally posted by Whaler
          Gerd
          It feels that way! Just using the mandrel and stops from Berea (which I think are the same Woodcraft sells). Might have to do with the bloodwood I was using, very dense but gorgeous!
          Gerd
          • Doghouse
            • 79
            • VA.
            If you have trouble getting out the mandrell, throw the whole thing in a bag and put it in the freezer. The metal will shrink enough.
            I tend to epoxy them on anyway. It keeps people from unscrewing them. Exp. with the cork and chrome as I have had people loose the cup washer
