Purpleheart Lamp
  • RayintheUK
    • 1792
    Purpleheart Lamp
    Here's a fairly simple design table lamp in purpleheart. Base attached with a 1" tenon. Finish was sanding sealer followed by Rustins plastic (two part). Overall height of column is 14", base diameter is 9" - a Christmas present for my daughter.
    Ray.
    Did I offend you? Click here.
  • bmyers
    • Jun 2003
    • 1371
    • Fishkill, NY
    • bt 3100
    Nice job Ray! I like it. Hey uh, how do you get the hole down the middle? Extra long drill bit?
    I have some butt ugly lamps around my place in need of replacement. (the 80's are sadly over it seems when it comes to indoor lighting)
    • Ken Weaver
      • 2417
      • Clemson, SC, USA
      • Rigid TS3650
      Nice work Ray, she'll love it!!
      Ken Weaver
      Clemson, SC
      • JeffW
        • 1594
        • San Antonio, Texas, USA.
        Ray, That is one nice lamp. Great job on the turnings.
        Measure twice, cut once, screw it up, start over
          Extra nice, Ray. I see another LOML project coming up.
          ken
          • kwgeorge
            • 1419
            • Alvin, TX, USA.
            Man that is some kind of pretty! Going to have to try one of those too. Nice job.
            • RayintheUK
              • 1792
              Bill,
              My lathe has a hollow tailstock and came with a hollow live center like the one here: http://www.axminster.co.uk/product.a...=21274&recno=4 This has two sizes of removable point and a ring center. You mount the piece normally, then drive the tailstock in until the point is buried far enough for the ring center to bite a ring into the end. Back off, remove point, engage the ring center, then proceed to remove the wood from the center with a 36" shell auger (1" at a time in order to clear the debris. If you try to do more there's a risk of the auger jamming and becoming uncontrollable). Burrow halfway, then mount a counterbore drive (like this one: http://www.axminster.co.uk/product.a...=21257&recno=3) into the headstock, replacing the point in the hollow center. Repeat the process, remove point, burrow away until you meet in the middle. The 5/16" hole made during the first half exactly fits on the 5/16" nose of the counterbore drive. Once you've completed the column turning and cut a 1" tenon on the base end, slacken off the tailstock so that it lightly supports, hold the piece still by hand, start the lathe at a slow speed then drive the piece forward until the counterbore drive cuts a shallow (1/8") recess for the brass lamp-base holder.
              Sounds like a load of work, but you can do it in about the time it took to read this reply!
              Ray.
                Ray
                The only word I can think of is BEAUTIFUL
                • GeekMom
                  • 752
                  • Bonney Lake, WA.
                  • Shopsmith Mark V
                  Wow! What a beautiful shape and finish! She'll love it.
                  Karen
