I just recieved my Vari-Grind and have a couple of questions I hope you all can answer.
In the instructions on grinding a bowl gouge, Oneway says to set the Vari-grind leg angle to the down position (close to the front, end facing grinder wheel). I did that and using a cheap 3/8" BBest bowl gouge got a good fingernail grind but the edges seem's awful long...quess my question is what is the angle for the leg should I use? Also how do you measure the leg angle? I have tried protractors, ect and because of the way the jig is made can't really get a good measuerment. Has anyone figuered out the angle of each of the notchs for the leg? It would sure be a lot easier if Oneway would stamp the degree marks next to the notchs on the Vari-grind jig.
Also tried it on a spindle gouge, quessed the leg angle to be around 35 to 40 degree, well the 1st attempt made a huge sweep on the side wings about 1 inch. How do you set this dang thing for spindle gouges. I just kind of quessed on a second attemp on the leg angle and it came out a little shorter on the side grind and it cuts pretty good...
Don't get me wrong its a great tool but not that well documented...I have the printed instructions..watched the videos on the Oneway site...but they all seem, well just not clear...at least to me or maybe I'm just thick headed...Hope you all can kind of understand all this not sure if I'm being clear....any help anyone can give me I would sure would be grateful...hate to keep grinding away that expensive metal..
Thanks
James
Thanks
James
