A New Vise
    • 8799
    Originally posted by Whaler
    gerti
    I raise the blank above the bottom of the vise so there is clearance for the bit to go through, there is no need for it to sit all the way down.
    A TIP here: There are some woods that are very brittle and even with the most care, will blow out 40, 50, 60% of the time if drilled all the way through. For that reason, on brittle woods, it is recommended to cut the blank about 1/4 inch to 3/8 inch longer than necessary and drill to close to the end but not all the way through. After doing this, remove the blank from the vise and cut the end off. Saves a lot of blow outs on gnarly burls and brittle wood like snakewood.
    • bigstick509
      • 1227
      • Macomb, MI, USA.
      • CrashResq
        • Apr 2003
        • 199
        • Okmulgee, OK, USA
        Hank.... Thank you a LOT for that tip (though now I feel like a complete idiot... that's such an obvious solution)... That's why I read this board
        Bill (in OK)
