Turning Ipe
    Turning Ipe
    Has anyone turned any?
    Yesterday a contractor friend gave me some beautiful cut offs which fit in the pen and bottle stopper size range.
    Any suggestions?
  • final_t
    • 1626
    The desisty is really high on this wood, so I would expect it would be like turning Coran (or whatever it's called - countertop stuff).
    Send me some and I'll tell you!
    • MikeMcCoy
      • Nov 2004
      • 790
      • Moncks Corner, SC, USA.
      • Delta Contractor Saw
      I've turned a couple but did about triple the sharpening in the process. I turned some Dymonwood about the same time and they were comparable as far as density.
        I tried a piece of that Ipe today.
        Harder than H but not to bad to turn. I'm not impressed with the results though.
        • Scottydont
          • 2359
          • Edmonds, WA, USA.
          • Delta Industrial Hybrid
          Harder than ****, dulls your tools faster than a 5 year old. I agree about the not impressed with the look (my experience too.)
          Scott
          Edmonds WA
          No coffee, no worky!
            I ran a 52" piece through my Veritas doweling rig, and had to sharpen all the blades after. Fortunately for my lathe and tools, all i did on it there was sand and finish. Sanded nicely, but I wouldn't want to keep up with the tool sharpening that would surely result from working with it much.
            • don_hart
              • 1005
              • Ledayrd, CT, USA.
              Use it all of the time
              I use it often and it turns well. I have done quite a few pens out of this material. Here are a few examples http://www.hartwoodcrafts.com/pens/pensmat.asp?mat=IPE
              It is a very dense wood but I find it easy to turn. It will dull your tools like any other dense hardwood.
              Don
              Don Hart
              You live and learn. At any rate you live.
