What speed to turn Acrylic Pen Blanks
  • TB Roye
    • 2969
    • Sacramento, CA, USA.
    While visiting the Kids in Idaho for Thanksgiving, my son the grandkids and I went to the Local Woodcraft. While there my son purchased a bunch of Acrylic Pen Blank in the colors of Boise State, remember them Oaklahoma? So now I have a dozen Blue and Orange pens blank to turn. Question is what speed should I use on them? I have been practicing on a blank at 1250 rpm. Is that to fast, to slow. It seem to be ok just want to know correct speed before I start on the Boise blanks.
  • final_t
    • 1626
    I turn mine "somewhere in the middle" of the speed range, so 1250 sounds about right. Slow down to the bottom speed when you sand & finish polish (recommend wet sanding, even if using micro mesh). Can't wait to see the results!
    • Zenaca
      • 116
      • Idaho
      I been turning those just as fast as my Jet 1236 will go then about half speed for the sanding with Micro Mesh. Havnt had any problems
      Bud
        • 8781
        Lately, I have been turning at 2400 and above for shaping and getting a lot less snags.
        I am going to get a full variable speed motor or lathe in the future because I spend so much time changing speeds on pens according to the need.
          I turn all of my acrylics at 1250 and use sharp tools.
          For finishing I drop down a notch and sand thru 600 then switch to micro mesh wet thru 12000 and as final step I use 3-M fiberglass cleaner wax.
