Captive Ring Tutorial
    This was done by a member, Doghouse, who hasn't posted for awhile. He offered it if someone would host it, so I stuck it on one of our sites. I have found his process to be very good.
    Captive Ring Tutorial, by Doghouse
    One of my first ones using his technique.
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    Excellent! Thanks for hosting this!
    • MikeMcCoy
      • Nov 2004
      • 790
      • Moncks Corner, SC, USA.
      • Delta Contractor Saw
      Thanks Ken - very easy to follow
      • SteveR
        • 494
        • USA.
        Thanks for keeping this Ken...great tutorial...I learned some things about the use of the captive ring tool and starting it on the outside first. I also had cut in 4 rings and sure enough 2 broke, so the more the better.
        BTW great goblet.
        So far, when I cut my rings free, there seems to be a little "rib" left on the inside of the ring. Do you have that problem or do they cut pretty clean? Maybe I just need to get my rings to a smaller diameter.........or a bigger ring tool
        Steve
        • MikeMcCoy
          • Nov 2004
          • 790
          Steve - I tape a piece of sandpaper on/around the piece and when the ring is cut loose, you can hold the ring and let the lathe sand off the rib.
            BTW great goblet.
            Steve
            Steve,
            Yes, I also have the rib on the inside. I've tried to cut the ring and leave no rib, so far, no luck.
              Well, ain't you the smartie!?? :-)
              Thanks Mike.
              • MikeMcCoy
                • Nov 2004
                • 790
                Thanks Mike.
                I can't take credit for that as it was one of many things I picked up on a Lacer skew video.
                • SteveR
                  • 494
                  • USA.
                  Steve,
                  Yep I did the sandpaper thing too...figured I was doing something wrong with my ring tool.
