Advice needed
    Advice needed
    Am ready to build a bench for my Jet 1220 and am unsure of how high to make it.
    With the tool rest all the way down I am thinking even with my belt line.
    Using your belt line as a guide where does the tool rest sit and be comfortable for you.
  • RayintheUK
    • 1792
    I'd not thought of using the tool rest as a guide to lathe height - I use the "drive centre level with my elbow" method, which seems to work fine.
    Ray.
    Did I offend you? Click here.
    • Popeye
      • 1848
      • Woodbine, Ga
      • Grizzly 1023SL
      Ya made me have to think early in the morning Dick..... and it's hard!!!!
      I can't change the height of my lathe but if I could I would make the centerline of the head and tailstock just slightly below my elbow height as that's where my guide hand would naturally fall on the tool rest. Lower and you make yourself bend which hurts my back in a very short while. Higher makes it easier for old eyes to see but doesn't feel natural to me and makes my arms tired. (I base that on using a friends lathe to turn a couple of bowls)
      BTW Dick, all of us are waiting to see pictures of this new shop. Pat
      • Popeye
        • 1848
        • Woodbine, Ga
        • Grizzly 1023SL
        Ray.
        As I was typing my reply to Dick I got to thinking about you Ray. Hadn't heard from you in a "coon's age." Pat
          The height of my lathe center is about an inch above my elbow, and is comfortable for me. I think a lot is going to depend on you, as in your build, your posture, even the length of your carving tools. When I cut, I use an area of my hip to brace the handle of the tool, hence my preferred lathe height. If I'm doing very detailed work when I hold the tool freehand, this height is a little tall, so I stand on a short 2" platform with a rubber mat glued on top.
          • final_t
            • 1626
            I think that I have mine set like the others suggest, spindle at elbow, but lately I seem to be bending over it a lot which hurts my back, so I'm thinking about raising it 2 inches or so and see how that works out.
              If I raise my fore arm level (to the ground) and put it parallel to the center line of the my lathe, the center line is the same height as the middle of my fore arm. That may seem a little high for some, but I don't get any back problems with turning at that height, plus I am able to see everything well.
              I do have back problems considerably but this height is ideal for me on the lathe. In the past if I had to bend over because something was an inch or two too low, I could adjust with my arms and hands but in reality the back makes adjustments too and ends up giving me fits.
              In my experience, a table that is one or two inches too high from ideal causes less back pain than a table one or two inches too low from ideal. I err on the side of high and have no complaints.
