I hate sharpening, but I found that with some woods (rosewood?), dull chisels are a bear to work/play with. So I finally set up the bench grinder with my Wolverine jigs. Using the gray stones that came with the grinder, I proceeded to sharpen my gouges. Since I've never done this before, I had no idea how long I was supposed to hold the chisel against the stone, resulting in turning them blue (not sure if that's the right term).
One chisel looks pretty bad. I've since replaced the stones with the pink ones from Woodcraft.
So.... How do I fix my ruined chisels? They're all HSS. The only thing I could think of is to spend time to grind the chisels down until I grind through the ruined edges. Is that really the only option? I mean, I don't mind, but it takes a while because I did a really bad job with them initially. I'm also getting pretty paranoid about ruining them again, and I end up taking a very long time with each chisel.
Thanks,
Anna
Thanks,
Anna
I knew about the trick with the marking pen to see when you're done sharpening, but I didn't think of using that to check the bevel.
Even if I had one, it'll probably take years before I get the nerve to even try it. Still good information, though. Thanks.
