I was turning another bowl and it was starting to wobble a tiny bit so I loosened the chuck and held the bowl in place and tightened it back up (to much I guess)....made a few creek sounds and I seen a crack. I removed it and tried to pry it open a wee bit and put some superglue in the crack. The crack appears to go from the center to almost the outside edge on one half only. Will super glue hold till its finished (Im almost done) or should I try something else???
I was thinking break it in half and gorilla glue it but not sure how I could clamp it back together and if its not perfect the crack will look worse than it does now. Its barely visible when took it out of the chuck....
