I'm a bit confused. I've started getting into turning pens. I haven't turned much else, yet. I've gotten alot of different information about finishing turned projects.
I went to "The Woodworking Shows" when they were in town a month or two ago. I went to some classes on finishing & pen turning. The guy doing the pens never used anything above 400 grit sand paper & made what appeared to be perfect pens. He used friction polish on one pen & a friction polish/laquer finish on another (it was a several step process). I've bought the micro mesh kit (up to 3600 grit) & while this is better than sandpaper, I can still see dull/shiny rings on the wood after the finish is applied. MM seems to be popular with the pen turners here, but, I've had an aquaintance who does a fair amount of turning tell me I should be using buffing wheels. This seems a bit awkward for pens...
My other confusion is in the finishes themselves. At "the woodworking shows" the guy doing the finishing classes (general finishing, not specific to turning) mentioned that laquer is one of the least durable finishes available. The guy doing the pen classes praised laquer for its durability. The guy at my local wookworking store told me either the friction polish or laquers were fine because you don't really want to completely seal the wood. Alot of the pen turners here seem to like CA glues for finishes.
As you can see, I'm not really sure who's giving accurate information. Maybe they're all right if you want different options.
