Pen Finishes
  • ryan.s
    • 785
    • So Cal
    Pen Finishes
    What do you guys use to get a nice glossy finish on pens? I tried the HUT polish (satin then gloss two step process) but the finish leaves a lot to be desired. It doesn't come out close to a glossy glass like finish. Any tips would be appreciated.
    Thanks.
  • Jim Boyd
    • 1766
    • Montgomery, Texas, USA.
    • Delta Unisaw
    I use either lacquer or ca glue. A good place to go to reasearch different finishes and how to apply them is http://www.penturners.org/forum/default.asp
      What Jim said. I used the CA method for a while, now for gloss I use rattle can lacquer.
      • gerti
        • 2233
        • Minnetonka, MN, USA.
        • BT3100 "Frankensaw"
        Do you just spray it on, or is there some 'on lathe' process involved?
          I usually just turn the spindle slowly by hand and spray the blank on the lathe. A few light coats. If I'm doing a batch of pens I put the blanks on a small dowel seperated by spacers and spray the lot at one time.
            • 8799
            CA Glue for me. Does great but has a learning curve. IMHO, tougher than lacquer.
              Yep, CA is about as tuff as it gets, AFAIK. Haven't tried to dip in Epoxy yet! ;-D
              Ummmmm, that's a thought.....
              • onedash
                • Mar 2005
                • 1013
                • Craftsman 22124
                I saw a pen recently and it was finished with super glue. I was surprised but it looked really nice. Never would have guessed it was glue....
