Hollowing Small Turnings
    I'd like some input on how you folks hollow small vessels.
    Turning goblets, about 1.5" diameter and making the vessel about 1.5-2" deep with straight sides, I'm having issues. Shallow depths are not a problem, it's the getting deep into a small opening that gives me catches.
    Following the Sorbey and other videos I use a spindle guage, cutting from the center out on the end grain.
    Any suggestions appreciated.
  • Tom Miller
    • 2507
    • Twin Cities, MN
    Feel free to cheat, and use a forstner bit to hog out as much material as you can.
    Regards,
    • RayintheUK
      • 1792
      You could also try a ring tool, Ken. I'd borrow one first, if you can, as not everyone gets on with them, but they're quite good with end grain.
      Ray.
      Did I offend you? Click here.
      • gerti
        • 2233
        • Minnetonka, MN, USA.
        • BT3100 "Frankensaw"
        Hollowing endgrain is typically a job for a scraper.
        • final_t
          • 1626
          That's what I first thought also, but then I realized that he's turning something that overall is smaller than the usual scraper - so the inside is probably something like 3/4"?
          I'm with Tom on this one, go for the foster bit and clean up what you can otherwise.
          • kwgeorge
            • 1419
            • Alvin, TX, USA.
            Well speaking as someone who has done just a few smaller turnings I will chime in here. For general hollowing I love my Kelton Mini Hollowing set for sure. These tools make short work of the job and you can control the cut by rotating the tool handle a bit.
            http://www.woodturnerscatalog.com/cg...n&key=095-0608
            I also have a 3 piece Sorby set that works rather well although I am not finding a picture or link for at the moment.
