Burn wire and spools
  • Tom Miller
    • 2507
    • Twin Cities, MN
    I finally figured out that the wire used to "burn" rings into turnings is basically any metal with low-heat conductivity. I came across some tungsten wire, and made these, uhhh, spools as a way to hold onto the wire, and to store it without getting all tangled:
    You can see some burn rings on the spools themselves. (Ahhh, but how did he hold the wire before he made the spool?! [)])
    Regards,
  • gerti
    • 2233
    • Minnetonka, MN, USA.
    • BT3100 "Frankensaw"
    Much prettier than the copper wire with off-cuts twisted at the ends I use!
    Gerd
    • tribalwind
      • 847
      • long island, ny.
      nice than the romex wire im using haha
      • Tom Miller
        • 2507
        • Twin Cities, MN
        Thanks, guys!
        I could have sworn I tried copper wire, and failed to get it to burn. So I assumed the wire type was more important than it really is.
        My setup is usually more like the ones you two mention -- I obviously had a little too much time on my hands one evening! [)]
        Regards,
