I'm getting ready to put up some fencing, and I could use a recommendation.
The fence is a dog-ear style, with 1x6 pickets mounted to two 2x4 rails with 4x4 posts every 8' or so. I did a section on the other side of the house years ago, and it's held up well with the dog leaning on it. I put the 4x4's in oversize post holes with cement and they're pretty solid.
On the short section I did before, I attached the pickets with screws to avoid hammering and possibly loosening the posts. This was before I discovered this forum and the wonder of air tools.
I'm thinking a nailer would make the job quicker and wouldn't shock the posts too much. My questions are:
Will the nailer impart much shock to the posts? I've only got a small nailer at the moment, don't know how the larger ones behave.
If a nailer is the way to go, what gage should I be looking for? Keep in mind my max nail length will only be about 2"
Suggestions for a reasonably priced nailer? I can't see investing a few hundred bucks on something I won't use very often. I'm more into furniture making than large home improvements.
Finally, (yes, finally) is this a good route to go? The section built with screws has held up very well. Never a loose picket. Are framing nails glue-coated? What would you recommend, especially since it will be exposed to the weather. Okay, that was more than on question.
I'll stop now and bask in the glow of your illuminating answers!
