ryobi 18v circular saw guide which?
  • gychang
    • 188
    • Sacramento, California
    • none
    I have 5 1/2" saw has a fence guide slot builtin anyone know which work?
    I have the Craftsman version of that saw (C3), which is made by Ryobi. If you're looking for an aftermarket version of the rip fence, any with a bar that is 15/32 wide by 3/32 thick should fit.
    • gychang
      • 188
      • none
      Is that "standard size"? Can u recommand one from amazon.?
        I double-checked the dimensions against my corded B&D circular saw, and my other Craftsman circular saw - and yes, they are all the same. So my guess is standard size - however, that doesn't mean every brand will be on standard - so you might consider the following item on Amazon, which has several bar size options, seems like a reasonable price as well.
        http://www.amazon.com/Milescraft-140...+saw+rip+fence
        But I hardly use mine anymore in preference for using a clamping straight edge (if your application allows) like one of the following:
        http://www.amazon.com/Bora-540902-Cl...+cutting+guide
        Unless you're rough-trimming lumber, these will give you a better guide edge to control the saw for trimming boards and sheet goods.
          Addendum:
          Checking for dimensions on some of the other brands, this one also looks to be compatible based on specs given:
          http://www.amazon.com/Dewalt-DW936-R...+saw+rip+fence
          Last edited by Bill in Buena Park; 08-05-2014, 02:29 AM. Reason: Hyperlink correction
            I have seen more variance in thickness then width. (although I know they make them different sizes)
            The home stores typically carry one (Walmart I think still sells B&D, Porter Cable branded at one of the box stores), and you should be able to walk in with your saw to find out (at least at the home centers/local hardware stores).
            A sawboard should be another idea.
            Also several video's of how to make them on Youtube.
            • gychang
              • 188
              • none
              I have sawboard but very difficult to repeat the same width of a cut...
