For work, we have a rewards program whereby we get points and then can spend them in an online store for merchandise and other things. I've been eyeing an Earlex 5500 HVLP system for a while, and I finally have enough points to pick it up!
But I also see that the "store" we can order things through also has just the gun from the 5500 available, as well as the various size needles.
Here's the thing, I have a Graco until that's much like the other $100 all plastic entry level versions from HF, Rockler, and Wagner.
Since the hose on the Graco and the Earlex systems are both friction fit into the guns, I'm wondering if maybe I can just get the Earlex gun for half the cost, and use my Graco turbine to drive that gun. Then I get the better performing gun for HVLP, but I can forgo the cost of the Earlex turbine.
Or does the Earlex HVLP gun need more CFMs than the Graco turbine can push, making it necessary to get the whole setup?
Either way, I'm getting something for free (well kinda, if you don't count the fact that I've been working looong hours on the project for which the points were awarded). But still, there's that opportunity cost with spending twice as much for the whole system rather then just getting the gun.
Any thoughts or input would be appreciated!
Thanks,
Travis
Thanks,
Travis
