Vertias Dowel Maker HELP!!!!
  • Wolverine
    Handtools only
    • Aug 2013
    • 3
    • Oshawa, Ontario
    • porter cable 10" Hybrid
    I bought a Dowel Maker Master Kit with the inserts for making Dowels from 1/4" to 1" from Lee Valley Tools here in Ontario.
    The Vertias brand is awesome but I cannot seem to get a dowel that doesn't look like it has been shredded. I tried with pine, then I thought that was too soft so I went to Maple and still the same result. I am using a Rigid Cordless Drill with two speeds. If someone has this and has gotten better results, can you please message me as to how you did it.
    I send photos if that will help.
    On Youtube, there were a few video's where people made their own dowels, with a saw blade (mostly looked like reciprocating saws), and going through a hole.
    They all needed to be sanded after, I would expect that to be common with any of them (they left them in the chuck and ran sandpaper over it).
      I haven't tried their dowel makers, but have you honed the cutter?
      From the instructions: The blade is supplied with a 30° bevel ground in a 7" radius. As supplied, the cutting edge is adequate for rough work in most woods; however, accuracy and surface finish will be improved with additional sharpening.
      *edit- Ok, you have that other jig (I'm jealous!)
      Did you check the troubleshooting section of their instructions?
      http://www.leevalley.com/US/shopping...s.aspx?p=40743
      Try adjusting the feed rate, and maybe the front blade after changing the speed.
      • big tim
        • 546
        • Scarborough, Toronto,Canada
        • SawStop PCS
        Sounds to me that the "fine" blade is not touching the dowel!
        Regards,
        Tim
        • DannyT
          • Sep 2012
          • 28
          • Groveport, OH
          the instructions seem a lot more complicated than the old stanley dowel maker i was lucky to find but looks like it would make nice dowels once you got it setup.
          • Wolverine
            Handtools only
            • Aug 2013
            • 3
            • Oshawa, Ontario
            BIG TIM,
            A fellow Canadian EH. I live in Oshawa.
            Will definitely check the "fine" blade.
            Pelligrini,
            I will most defintely try adjusting my feed rate as well as changing the front blade.
            I wanted to today but I am trying to finish up a Victorian Style Screen door for my parents.
            Will keep everybody up to date as my progress continues.. Thanks for the quick responses so far. This is great
