Vintage Hacksaw
  • pushrod
    • 320
    • Panama City, FL, USA.
    Vintage Hacksaw
    A dear friend passed away unexpectedly a month or so ago. I've been trying to sell off his stuff for his daughter.
    Anyone need three (yes, three!) electric jigsaws?
    Anyhow, he had an old hacksaw that looks like the one pictured here:
    http://lounge-o-rama.com/images/dreiers_hacksaw.jpg
    It has "N.J.F." on the red plastic handle inlays. The "J" is stylized with an exaggerated crossbar.
    It is missing the pins or whatever was used to mount the blade. Anyone know what was used? I'm thinking some small nails, cut short would hold the blade when under tension.
    Cheers!
    \"The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.\"
    Cheers!
    You could likely get by with a good fitting common nail, and nip off the end.
    • Tom Slick
      • 2913
      • Paso Robles, Calif, USA.
      • sears BT3 clone
      I have the same hacksaw, I bought it in the 1990's. A nail cut short would function exactly the same as the original pins.
      I can post a picture of the pins if you would like.
      • pushrod
        • 320
        Tom, Thanks, but I took Cabinetman's advice.
        I took two galvanized deck nails, marked them for the blade engagement spot and overall length, then chucked them in my drill press.
        Using a Dremel cutoff wheel, I cut a notch for the blade, then cut off the unneeded body of the nail.
        I don't know what the original pins looked like, but these work great!
          Sometimes it's that simple fix that works.
            I lost the screw/holder on my coping saw several years ago. I notched a carriage bolt with my dremel as a replacement and it has been working fine since.
            • annunaki
              • Jan 2008
              • 610
              • White Springs, Florida
              • 21829, BT3100, 2-BT3000(15amp)
              Would a small machine screw with a locking (nylon insert) nut suffice?
              http://en.wikipedia.org/wiki/Fileodecahedron.gif
