Flush Router Bit Diameters
  • Holbren
    • Oct 2004
    • 709
    • Orange City, FL.
    You have received good advice for flush trim bits where the bearing is the same diameter as the cutter. For pattern bits where the bearing is on the shank, the 1-1/8" bit has a more substantial bearing and less likely to fail. If you do the math on a 3/4" pattern bit with a 1/2" shank, there is only 1/8" of bearing width making it a delicate bearing.
    Brian
    www.holbren.com
