Using a Plunge router as a drill press
I haven't done dog holes in a bench but I have done mortises for the tendons of a railing along a long set of stairs, with a router. C-man is right, you really do have to clamp it to be sure. I used a guide the router's base fit in and had a plug of plexi with cross hairs on it that I used to align things with. When set the guide was clamped in place and the router replaced the plexi and I was set to go. I also found that the router had to set in the guide exactly the same way as the router base was not perfectly centered around the bit. As expected you have to have a vac there to keep the hole clean.
I think I would do dog holes in two or more steps. Drilling out with a smaller drill bit and then finishing with the router. Not having to cut the center of the hole with the router bit should make things go easier.
MLCS has an upcut 3/4 spiral bit that is 3.25 long that might make it through the bench top if not then a forstner bit to finish would work too.
good luck
BillComment
