Steel sanding pads
    • 8803
    Steel sanding pads
    While in Japan, I bought a few of the sanding pads that had steel for the sanding pad itself. You can see them here:
    http://www.fine-tools.com/nt-dresser.html
    I just took if for granted that this type of pad was widely available. But in looking back here and online, I noticed that this is primarily a Japanese product. In Japan, I even saw 5 inch metal round pads for sanders and with different grits, some even course enough to be used as a thick paint stripper (Looked like it could strip thin tree bark off of a young tree.)
    I have been looking for something like that for my sanders over here - to quickly strip several layers of paint off of old walls. However, I cannot find the metal plate type of sanding disks over here.
    The reason that I am looking for "metal" is that it is my experience that these metal sanding plates do not load up like normal sand paper, clean very easily, and stay abrasive a looong time.
    Anyone know of any?
    Not like those. I have a pack of Microplane discs for my ROS, but I haven't used them yet. http://www.amazon.com/Microplane-330.../dp/B000HE9VQI
      • 8803
      The Microplane looks like it would take a hunk out of something. It looks like it is more for cutting. That might work but I think a rasp like disk would be best.
        They sure do. The reviews of them before I got mine a couple years ago were pretty good. I just keep forgetting I have them.
        There's also the Abranet products:
        http://www.leevalley.com/US/wood/pag...71&cat=1,42500
          Hank those look like something that should sell. Do I see Hank's Import as a new startup?
            • 8803
            I wish I had a stock pile of those! I just found 4 of them yesterday and wish that I had more. They are great for knocking of a the edge of a just cut board. I used to have course and fine but I could only found the fine set yesterday - when l was looking for the face plate!
              • 8803
              The abranet sure looks good. Abranet works great on pens. When I was turning pens, in some cases of delicate blanks, I sanded down the last millimeter or two with abranet.
              If I do go with a sandpaper type, I need 40 grit or so for paint striping.
