DeWalt DWP611PK - Wow...
  • Chris_B
    • 216
    • Cupertino, CA
    With the Amazon price drop & DeWalt $30 rebate, I took the plunge () on the DeWalt DWP611PK. I am *very* impressed! I like my Colt routers and use them often, but IMO the DeWalt is clearly superior (although durability is unknown). $150 (net) seems like a very fair price for all this functionality.
    The only things that I prefer on the Colt are the:
    1) Rubber grips (vs. the dimpled aluminum on the DeWalt)
    2) Offset base which has come in handy a few times (no equivalent on the DeWalt)
    3) Less-cheesy wrench (the DeWalt is flat stamped steel)
    4) Hard case (the DeWalt comes with a canvas bag)
    Except for the offset base, none of these are a big deal to me.
    A lot of the dado-style & circle-cutting work that I do is with small bits where a 1/4" shaft works well (and a smaller/lighter router is easier to handle), but without a plunge base I was reluctant to use the Colt (I'm not comfortable plunging fixed-base routers...). The DeWalt plunge action is very smooth, and feels similar to my Bosch 1617 (but obviously with less tension).
    DeWalt obviously did their homework, and hopefully the DWP611 is reliable. The overall quality is higher than I expected, with minimal slop and very precise adjustments. The little DeWalt has an abundance of small refinements that I'd read about in the reviews but are even more impressive in-person. One surprise is that the motor can easily be re-oriented 180 deg; this is helpful for handling the power cord or aligning the power switch with the correct base edge. And the clear polycarbonate bases are one less thing that I need to replace!
    Now all we need is a router with the same power & weight - but cordless!
    Mini Mr. Fusion, perhaps??
    (photo from http://www.ketzer.com)
  • tommyt654
    • Nov 2008
    • 2334
    Thanks for the mini review Chris. I was looking at that router but it was cost prohibitive as I'm a cheapskate, but since I have the smaller PC 7310 and the Bosch I'll prolly pass on this deal, but thanks for posting.BTW do you have 1 of these for your Bosch, I use this when routing a lot with mine,comes in very handy, http://www.amazon.com/Woodhaven-8320...ductPromotions
    • Bruce Cohen
      • 2698
      • Nanuet, NY, USA.
      Chris,
      Many thanks for the review. I've had my eye on this router set since they first announced it.
      As most of my work is the making of smallish sized jewelry boxes, I've really wanted something smaller than my DeWalt 618 set.
      You've made up my mind, Now who should I send the bill to?
      Bruce
      Samuel Colt did"
      • Chris_B
        • 216
        • Cupertino, CA
        I don't have one of these, but that does look very handy. I have made clear Lexan offset bases and might try making this one. Our local Tap Plastics often has polycarbonate cut-offs for *very* cheap, and I always scour the bin whenever I drop-in.
        BTW, for swapping bases the Porter-Cable centering cone works great, and only costs $4 at Rockler.
        Link
        • Chris_B
          • 216
          • Cupertino, CA
          Bruce
          LOL
          Good tools are Kryptonite...
            If it bounces anything like my 14.4v cordless drill it should be fine.
            • Chris_B
              • 216
              • Cupertino, CA
              BTW, I just noticed that this DWP611PK was made in Mexico. I think they need the money.
              FWIW, my DW735 planer was made in Taiwan, and also significantly exceeded my expectations.
              • Mr__Bill
                • 2096
                • Tacoma, WA
                Link
                Thanks for that info. I have just started looking for one, local ACE didn't know what it was much less have one. I'll be by a Rockler the end of the month and if it's still there, the store that is, I'll stop and get one.
                again, thanks
                on the left coast
                • kevincan
                  • 181
                  • Central Illinois
                  Amazon has $20 off a $100 Dewalt order sale going on now. They have this set for $175 - 20=155. There is also still a $30 rebate until the end of June.
                  I pulled the trigger on it earlier today.
                  • tommyt654
                    • Nov 2008
                    • 2334
                    Good luck with that rebate deal on this. I'm pretty sure you can't combine the 2 together. But if it works thats a heckuva deal for about $130
                    • jussi
                      • 2162
                      Thanks for the tip. I was able to use the Amazon discount and my rebate came today which is pretty quick.
