what double sided tape do we like for template routing and adhering scrificial surfaces to tool and workbench tops?
double sided tape
double sided tape
there's a solution to every problem.......you just have to be willing to find it.Tags: None -
http://www.amazon.com/36-Yard-Double...3141569&sr=8-1
works great for me for turning, routing and inlay's. very thin and strong, not like the mesh carpet tape.John
To invent, you need a good imagination and a pile of junk. ~ Edison -
I have seen and used two types : one, called 'mounting tape', is around 3/4" wide and has a spongy, thick body. Maybe it's been me, but it has never worked for me - the adhesion has sometimes been not strong enough for jigs and such; and it felt a bit unstable because of the thickness. And not sure what it supposed to help me mount, so no comments on that
The other type looks like regular masking tape (in thickness). I use the one I bought at Harbor Freight - 1.5 inches wide, white, cheap, and strong. Of course, I might spend 60 seconds in frustrated grumbling and swearing each time I have to separate the tape from the backing, but whaddoIknow? Maybe all double-sided tapes are like that. IIRC, I paid around $8.It is the mark of an educated mind to be able to entertain a thought without accepting it.
- AristotleComment
got a sku or a model number or brand name that you can recommend that they carry? same question for Radhak. thanks.there's a solution to every problem.......you just have to be willing to find it.Comment
Polyken, I'm lucky since I snag a roll or two from the carpenters whenever I go on show site, but great adhesion and re-set strength. Rated at around 3lbs per inch it holds well.
http://www.amazon.com/Polyken-Premiu...157369&sr=1-13Comment
