Greetings!
I recently picked up a used AP-12 Ryobi planer that appears to be in good order except for the drive belt. I ordered a new drive belt off e-bay and it arrived today.
Finding a manual for this unit was near impossible but I finally located one and a parts breakdown (easier to find). Neither has any info about replacing the belt.
I removed the outer casing and exposed the two pulleys where the belt attaches but do not see any way to adjust the tension to make installation possible.
The belt is a poly urethane type ribbed on the side that contacts the pulleys which have matching grooves.
I tried putting the belt in hot water for 10 minutes to see if it would loosen up like a poly bandsaw tire but no luck there.
Does anyone know anything about these planers inner workings? Do I have to take something else apart?
I am at a loss and I don't want to damage anything by exploring further without more information.
Thanks.
Kingsley
Thanks.
Kingsley
