Worksharp and chisel angle
  • jonathan55
    • Jun 2005
    • 119
    • Cleveland, Ohio, USA.
    I am starting to get bitten by the hand tool bug! I think one of the things that has held me back is sharpening or at least the mystique around sharpening. I finally practiced enough to sharpen a scraper and it's the coolest thing! I'm hooked! Chisels are next!
    Yesterday I bought the Worksharp 3000.
    I have a set of unused Marples chisels that I got when Rockler here went out of business. What angle is best for chisels? A secondary bevel?
    Any thoughts are welcome!
    Jonathan
  • herb fellows
    • New York City
    It really depends on your specific use, but generally I would say 25 degrees, with anywhere from 27 to 30 degrees for a secondary angle.
    I think you'll like the Worksharp, especially if you're working difficult wood where you need a quick tune up frequently.
    • Work Sharp
      Work Sharp here...
      Our intention when developing the WS3000 was to provide a 25° bevel setting for common bench chisels. If you desire a keener edge for paring chisels for example, you can sharpen them to 20°. If you plan on using a mallet to stike your chisels then I would recommend a more robust 30° angle. The 35° setting was intended for mortising chisels.
      What would I recommend?
      Sharpen your Marples to a 25° primary bevel and then micro-bevel them on the 3600 grit micro-mesh at 30°. This will do two things: make a strong cutting edge and make re-honing the edge a 3 second chore.
      Hope this helps. If you have any more questions please call us at 800-597-6170.
      We love hearing from and helping our customers.
      Work Sharper, Not Harder.
      • phrog
        • Jul 2005
        • 1796
        • Chattanooga, TN, USA.
        In his book, The Complete Guide to Sharpening, Leonard Lee states:
        "Chisels work best when ground at the lowest possible included angle consistent with edge retention."
        He suggests that a 25 degree bevel angle be used for "utility" chisels except in smaller sizes such as a 1/4 inch or narrower. His reasoning is that mallets are often used on utility chisels and if you hit the smaller chisel with the same force as a larger chisel, you will transfer more force to the narrower edge and, therefore, may deform the edge. He considers it appropriate to put a 30 degree bevel on these narrow chisels. I recommend Leonard Lee's book to anyone who is interested in sharpening.
        Basically, his recommendations are the same as Work Sharp's.
        Richard
