I'd been mulling over options on how to get 4in DC on my AP1301, which comes with a 2.5in shopvac port (and works very well with the shopvac) - but I wanted to take advantage of the chip separator on my 4in DC line instead of replacing shopvac filter bags.
I was considering cutting a 4in port in the upper plastic blade cover housing and retrofitting a 4in DC port, but saw a concept of mounting a segment of 4in DC pipe that could be connected to the DC line - so I came up with this retrofit:
1) Removed the yellow plastic cover attachment at the back;
2) Cut a segment of DC pipe, and removed a ~2in wide segment from the side of it, to fit over the chip ejection section at the back of the planer
3) Drilled and fastened some brackets to hold the DC pipe in place
4) Added some duct tape to seal the small gaps above and below the pipe
5) PVC-glued some couplers to each side of the pipe
6) Made a cap-gate to close off one side
My DC hose plugs into either side, depending on planer orientation and proximity to my DC line. Ran some tests on planing 2x4, and there was sufficient through-put to pull 95+% of the chips. She ain't pretty, but she works, and I like it.
Pics below - thanks for looking.
