Which HF sand blaster?
  • lago
    • 473
    • Lago Vista, TX.
    I am starting to restore an old Delta 8" jointer and need to remove the sloppy crappy paint job the PO did.
    HF has 2 in my price range:
    http://www.harborfreight.com/cpi/cta...emnumber=30979
    and
    http://www.harborfreight.com/cpi/cta...emnumber=37025
    Anybody have any experience with either?
    TIA
    Ken
  • Mr__Bill
    • 2096
    • Tacoma, WA
    The size of your compressor will make part of the decision for you. Whichever you get make sure you can get replacement tips. They wear out fast and the bigger they get you use more air and sand.
    I haven't used either, I got an even cheaper one from HF. I am always stopping to add sand, which isn't bad as it gives the compressor a chance to catch up.
    a real man can give advice on something he knows nothing about.....
    • scmhogg
      • 1839
      • Simi Valley, CA, USA.
      Ken,
      I also, have no experience with either of these units. I have a friend with a large compressor and sand blaster.
      See if the unit you purchase will handle baking soda. It is easy to clean up and not as bad for your health.
      Steve
      • Lonnie in Orlando
        • 649
        • Orlando, FL, USA.
        Ken:
        I have the HF #37025 connected to this HF compressor
        This is the only sandblaster I have ever used, so take my info with a "grain of sand." I've blown paint off of a few steel items. It's pretty effective if I get close to the workpiece. A lot faster and better result than using a wire wheel. Sometimes blows short bursts of empty air.
        Northern Tool sells blasting media pretty cheap. I have also used play sand from HD ... make sure that it is dry.
        Use full protection goggles, good dust mask, ear plugs (to stop sand), hat, long sleeves, gloves, etc.
        Good luck with your jointer restoration.
        - Lonnie
        >> EDIT:
        Info on Sand Blasting Basics. As noted in the article, the pressurized HF blaster #30979 may be more effecient (?)
        • John Fox
          • Jan 2010
          • 7
          Avoid the sand blasters, hazardous to your health
          I don't know about these but I tried the red bottle sand blaster on a bike frame. It took a long time and it was a mess everywhere. It plugged up a lot too. I didn't have a strong enough compressor either. In the long run I should have taken it to a place that does it.
