Is this a Delta Unisaw?
  • iceman61
    • Oct 2007
    • 699
    • West TN
    • Bosch 4100-09
    Is this a Unisaw, or just a cabinet saw?...or is a cabinet saw actually a unisaw?
    http://jacksontn.craigslist.org/tls/1642357629.html
  • sweensdv
    • 2873
    • WI
    • Baileigh TS-1040P-50
    Unisaw is the trade name for Delta cabinet saws. Modern era Unisaws will have at least a 3HP motor.
      Yep.. and a reasonable price for that matter.
        Looks like a Unisaw. They also called 'em tilting arbor saws. Being 220V it could be 3HP.
        • kramer katt
          • 375
          • SO CAL, USA
          • BT3100 and Craftsman 100
          You can see DELTA name tag
          but could be a Delta Hybrid saw (not a unisaw)
          Get model or serial no to verify
          --Albert Einstein
            Nope.
            It is a hybrid (NOT Unisaw). You can tell because the elevation wheel is too high (because that is where the trunnion is). The blade elevation wheel on a real Unisaw is several inches lower.
              Originally posted by cgallery
              Nope.
              Good catch CG.. if I had been looking closely I should have noticed. The crank wheel on a Uni-saw is lower indeed and it is larger in diameter. What threw me off is the motor cover is on the right side. Every left tilt Delta Hybrid I have seen the motor cover is on the left with the switch on left. This very well be an early right tilt and I do't think they make the right tilt anymore. The Uni and hybrid did come with a Biesemeyer.
              Hybrids and cabinets look similar on the outside. The truth lies inside the cabinet with the trunnnions. A Hybrid has them mounted to the bottom of the table where a cabinet saw had them mounted to the cabinet. The owner may be a lefty and re-mounted the switch to the right for personal perference for whatever reason as I have never seen any Delta come stock with switch on right but.. then again I have never seen every Uni-saw... I did have one for 4 years but a left tilt.
              One look under the hood would tell for sure. You cannot strickly go on HP as the early Delta Rockwell Unisaws had a 2 HP Marathon motor. But it would have likely stated Delta-Rockwell on the plate.
              But have to agree this is most likely a hybrid and if that is the case... I wouldn't give $500 for it and especially if it is the early right tilt which I suspect. About $350-$400 max would be a good price as long as all is well. I would call the owner and ask about the HP and if hybrid (which it is) and if it is left or right tilt.
              • iceman61
                • Oct 2007
                • 699
                • West TN
                • Bosch 4100-09
                You guys are pretty slick. I learn something new every day reading this forum. I had always heard about unisaws but had never heard of a hybrid. I'm not in the market for a new saw but like most guys here are with their tools, I can't resist a good deal. Just to cure my curiosity I may call to find out if it is a hybrid.
                I'll let you guys know what I find out, but it sounds like you already have it nailed.
