I have the Bosch PS20 and I love this thing. LOVE this thing. Only problem is, mine's not working properly. It's an issue with the electronic assembly. I'll pull the trigger, and only the LED tuns on. The motor does not. I used to be able to get the thing to work intermittingly previously by pulling on the trigger at an angle. However, now that doesn't even work.
So, I looked on Bosch's website, and the new electronic assembly is $46! (plus S&H, I can only assume). So, do I repair the thing or do I buy a new one? I've seen just the PS20 for around $100, and I know you can get a PS20 + the impact driver in a kit for about $160. So for a little more than 3 times the cost of repairing my old model, I can get the new model and the impact driver.
What do you guys think?
There are several Thomas tool & supply co's in the TC area. Maplewood, Bville, Mpls they are the fixit shop for Bosch. If you decide to replace with a new unit it might be worth your while to disassemble the thing. Just might figure what the problem is. If I have anything that breaks or quits working I always take that route. Sometimes I fix it and sometimes I fix it so no one can fix it. But I always learn something. Quite often it's only how hard it is to tear it apart and **** there's a lot of small parts in here.
