Replacement for hook-and-loop pad?
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    Couple of days back I bought the 'finger sander' attachment to the Multi-function tool from HF; essentially a thinner/smaller version of the triangular sander.
    Today, after 5 minutes of sanding with it, I found it had sanded thru the sandpaper and the hook-and-loop material that holds the paper ! Talk of aggressive sanding! I like the functionality but am loth to buy a replacement for $9 when the whole tool cost me less than $30!
    I thought I might save money by buying the hook-and-loop material, cutting to shape and gluing to the attachment. Anybody have an idea where I could find some such material? Might even be useful when other similar pads wear out.
    - Aristotle
  • Alex Franke
    • Feb 2007
    • 2641
    • Chapel Hill, NC
    Try a craft or fabric store -- Jo-Ann fabrics, for example.
      Lowe's (and probably HD, too; haven't looked) has hook-and-loop, in various sizes and shapes, that has an adhesive backing. Just cut, peel, and stick. I used to use it to anchor effects pedals to my pedalboard: it's VERY tenacious.
      I don't own the HF tool but from looking at the pictures, I think the widest H&L that Lowe's sells might be wide enough. Be prepared for a little sticker shock, though: the stuff is more expensive than you might think.
      • phi1l
        • Oct 2009
        • 681
        • Madison, WI
        Joann's has it I use that stuff just about everywhere. It comes in 1" wide rolls that are pre-glued. for easy installation.
        Hmmm that sounds like an interesting thread topic, "what do you use hook & loop for"?
        • BobSch
          • 4385
          If you don't have a fabric store handy try Michaels Arts & Crafts
          Bob
