A paper cutter as a woodworking tool? You betcha! In cutting veneers and plastic laminate, a paper cutter like this will produce an exceptional 90 degree edge.
If you cut strips of veneer or Formica type plastic laminate to fit, like in laminating a face frame, a paper cutter makes great cuts. Just a little pressure on the piece to be cut near the cutting edge to keep it from moving, pull the handle, and that's all it takes. It will cleanly cut cross grain. It beats using a snips, utility knife or an X-Acto knife.
