Wagner Power Painter - I Stand Corrected
  • parnelli
    • 585
    Originally posted by herb fellows
    OK, thanks for the advice. It is essentially the same, but i don't have the hose for the bucket, just the sprayer. To paint one door (just a side door to the house), I'd really hate to have to rent equipment. By brushing first, then spraying, will it kill the brush marks? If not, I guess there is no good reason to even bother spraying?
    I've had good luck on doors with the small foam rollers. It takes a bit of practice/luck, but you can do well without brush or roller marks.
    • dkerfoot
      • 1094
      • Holland, Michigan
      The Actual Painting is the Reward!
      I have the Wagner model that was the best available at the time. Using it has been hit or miss. It does much better with oil based paints than latex.
      It was a lifesaver when I had to prime the 100 year old joists in my basement ceiling. The way they sucked up the paint, it would have been a nightmare trying to brush all those angles and sides.
      Still - 95% of the time, you are much better off grabbing a brush or a roller. Why do you suppose that people who paint for a living hardly ever use a sprayer?
      Now, if they would come out with an automatic machine that would do all the prepping and taping, they'd have my attention! I am now at the point where I think of the actual painting part as fun. It is the reward for all the hard work put into scrapping and prepping. Especially once the priming is done.
      Doug Kerfoot
      KeyLlama.com
      • dkerfoot
        • 1094
        • Holland, Michigan
        In my experience, the best cure for brush marks is better paint. If you have a real paint store, ask for advise. Sometimes the person at the paint counter of the BORG is very knowledgeable too, but it is much more hit or miss.
        The 2nd best cure is a better brush. Be sure to lay the door flat to avoid drips and sags and help it level.
        Another very common mistake is to over brush. The paint should be put on thicker than comes naturally to most folks.
        I am personally incapable of doing a good job with a foam brush.
        http://greatpaintingtips.com/how-to-...ng/2009/01/27/
        Doug Kerfoot
        KeyLlama.com
        • Rand
          • 492
          • Vancouver, WA, USA.
          When I want to brush on smooth water based paint I usually turn to Sherwin Williams. I can't remember the variety but it lays down really well. It's also about 35 bucks a gallon.
          I have had decent luck in the past just thinning Behr Semi Gloss with water. Or, You might try a paint conditioner like Floetrol.
          Rand
          • herb fellows
            • New York City
            Yes, I've seen floetrol mentioned a number of times in my research.
            Thanks to all for the info.
