Parallel Clamps
  • jackellis
    • 2638
    • Tahoe City, CA, USA.
    Parallel Clamps
    I have a mix of used Jorgensen parallel clamps and some new and used Besseys. Don't know about anyone else but I've come to prefer the Jorgies for one somewhat trivial reason. It seems that after they've been tightened firmly, Besseys just won't let go. The teeth are deformed. I have to tap the head against the floor in order to get the jaw to slide.
    Any other opinions?
    The HF aluminum clamps are turning out to be very handy. Highly recommended, especially for the price!
  • sweensdv
    • 2873
    • WI
    • Baileigh TS-1040P-50
    There are many different trains of thought on this subject and my viewpoint is that you're over tightening the clamps. Over tightening can lead to glue starvation at the joint as most of the glue will be forced out by the excessive pressure. Take some scraps and do a glue up using your current method and one where you only apply enough pressure so that the clamp is tightened just a little past snug.
    • jhgrady
      • 297
      • Alexandria, Va, USA.
      I like the Bessy DuoKlamp's they are lighter and easier for me to use.
      John
      • Tom Miller
        • 2507
        • Twin Cities, MN
        ...I've come to prefer the Jorgies for one somewhat trivial reason. It seems that after they've been tightened firmly, Besseys just won't let go.
        I've never had that problem with my Besseys, but occasionally have had a Jorgy "freeze shut" when nothing was clamped in it. This is (or at least was) a common occurrence, with a reasonably easy fix. I think newer versions have a permanent fix(?).
        I usually prefer the Besseys (slightly) just because they're a little lighter & less bulky, and therefore easier to manage. The Jorgies are less tippy, and more solid, so for some projects (especially if they're going to be laid on the table), they get the nod.
        Regards,
