Congratulations! You got a great deal and you'll be surprised at how much you will use that sander in the future.
I am sure you are right and thats why I am so excited to have it as I can think of so many uses. The glue up I mentioned earlier from Sunday was for a cutting board made from a lamination of Cherry, Maple, Walnut and Padauk. Even when I planed the stock before glue up trying to minimize tearout was a real PITA. As I glued it up I spent ages thinking how to ogranize the grain in each strip so that when I planed the glue up it wouldnt tear out some more.
It was either that or lots of scraping, belt sander and hand plane. And thats before I resaw the block into 2 and have to do the other side
When I got the drum sander home all I needed to do was to pare off some of the dried glue run it through the DS with a few passes on each side and it is PERFECT
Given that one of the things I want to do is more boxes with exotics the idea of trying to use the planer wasnt exciting. Now I can easily resaw some of my valuable stock and precisely thickness on the DS with no worries of tearout.
We all make mistakes and I should know I've made enough of them techzibits.com
Remember that the drum sander is primarily for finishing, and that major thicknessing is still a job for a planer. If you must take more than a little material off on the DS, be sure to use heavy grit paper and many small passes. Getting too aggressive will result in clogged or burned sanding media.
Understand totally. I was thinking of the case where I may have some 4/4 exotic thats already milled and I want to resaw it. At that point each half will already have one flat face and all I need to do is true up the saw marks and make each half the same thickness. In this case it would only mean reducing it by 1/32 to 1/16 max.
Even for more general stock that may be rather tearout prone I can use the planer to get it within a 1/16 of final size and then use the drum sander to bring it the last step without the typical gnashing of teeth that acompanies a lump torn out of the middle of a fine board just as you thought you had escaped the planer enscathed...
