How much would you pay for this unisaw?
I wouldn't offer more than $300.00 since it is missing the right extension wing, has only a 2 HP motor and has a very old fence system that leaves a lot to be desired. A new fence and wing would cost at least $200, probably more. If you are looking to upgrade to a cast iron saw, you might want to check out the Ridgid TS360/3660 that HD is clearing out for $399. It won't have the mass of that unisaw, but you won't have to do any upgrading to it either. -
Looks kinda like a bullet motor (repulsion-induction)? Those are supposedly nice because of the power curve. I don't know how much the difference between a conventional induction motor and RI motor have been exaggerated, but If I were in the market for a cabinet saw I'd take a serious look at this unit.Comment
If the seller thinks that saw is in perfect condition then I'd give it a very good going over before I'd even make an offer. Someone will probably over pay for this saw but $200-$250 tops for me considering all the work you would have to do to clean it up.
I'm not a big fan of craigslist. Anything offered for sale there would have to be a smoking great deal or almost in NIB condition before I'd take a gamble on buying it.Last edited by sweensdv; 02-09-2009, 03:19 PM._________________________
"Have a Great Day, unless you've made other plans"Comment
$250 tops cause you will spend twice that getting it in real working order. New right side table, new fence (think Bies), miter gauge and one heck of a lot of elbow grease. Better give it a good once over before buying, check bearings, motor, pulleys, et al.
RAGS
Raggy and Me in San Felipe
sigpic
The real drawback is the missing table portion but that could be handled if you are going to build a saw center out of it. the other thing is that those older motors where also typically 1.15 or 1.25 SF (service factor) which means they could deliver 115% to 125% of rated HP without any problem. A 1.25 SF 2 HP would equal any 2.5 hp motor used on current saws. A full set of bearings for the motor and the arbor would be under $100.00 using Timken bearings. if you have the ability to install them. Adding the fence would cost between 150 + depending on which fence system you used. Grizzly's shop fox fence is an excellent fence.
I have bought 1/2 my shop from Graigslist and always test the tool prior to buying to check for any major problems but I can also fix most anything if there is a problem and just make my offer appropriately. So for about 600 max you would have a saw that you would have to spend well over 1000.00 to even come close to.Art
If I could come back as anyone one in history, It would be the man I could have been and wasn't....Comment
I wouldn't hesitate to pay $350 if it runs well and is good condition.Happiness is sort of like wetting your pants....everyone can see it, but only you can feel the warmth.
