Broken Cordless Drill-Driver.
  • GPA61
    • 712
    • Rancho Cucamonga, CA
    • BT 3100 & JET JWTS
    It's a Craftsman, 19.2 volt, 1/2".. I've had it about a year and a half. It just gave up the ghost. When I squeeze the trigger all I get is a squeeking from the battery pack but nothing happens. Yes, the battery is charged.
    Does anyone have any ideas? Can it be fixed?
    Thanks for your input.
    Claudio
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    squeaking from from battery or motor? do you own a voltmeter?
    • Zenaca
      • 116
      • Idaho
      Sounds like an opertunity to get a "new" refurbished Bosh 10.8 V Impactor from amazon for $79.99. I was just looking at them this morning.
      Bud
      • GPA61
        • 712
        Tom,
        No, it's not the motor. It's the battery pack that makes the noise. Yes, I do own a voltmeter. How do I start checking this thing?
        Claudio
        • Tom Slick
          • 2913
          • sears BT3 clone
          battery noise is strange. can you spin the check/gearbox/motor by hand?
          I'd check voltage at the battery after it has been in the drill and you've pulled the trigger a few times to see if the battery is actually charged. then I'd open the drill and check voltage at the motor with the battery plugged in and with the trigger pulled.
          • GPA61
            • 712
            I can spin the motor by hand. I'll check the voltage. I will also try with a different battery. I think I have three that will fit this one.
            Thanks for your suggestions. I'll let you know the result.
            Claudio
            • GPA61
              • 712
              Tom,
              I'm not getting much voltage. It's giving just a few mv and the copper strap around the switch gets hot. Bad switch, huh?
              Claudio
              • Tom Slick
                • 2913
                • sears BT3 clone
                not much voltage at the motor or battery? If you are talking motor I'd bet you're switch is toast. the next test I'd do is jumper wires from the battery directly to the motor ans see if the motor spins.
                • GPA61
                  • 712
                  I tried jumping and all I got was a big spark. I guess it's time to get another one. Thank you for all your help. Maybe Santa will get me one.
                  Claudio
                  • Zenaca
                    • 116
                    • Idaho
                    Claudio check out reconditionedsales.com they have a hitachi 18volt li ion drill driver with 2 batterys and charger and case for $85! The page shows in stock and ships in 1 to 2 days .http://s3.amazonaws.com/Reconsales/265/ds18dfl.jpg
