Kickback post from another forum
  • Gator95
    • Jan 2008
    • 322
    • Atlanta GA
    • Ridgid 3660
    Generally wouldn't link to another woodworking forum, but thought I'd make an exception.
    http://www.sawmillcreek.org/showthread.php?t=97828
    If you don't keep positive control over the piece between the blade and the fence, the only thing keeping it from a likely kick-back when the cut is completed is the kickback pawls.
  • backpacker85
    • Sep 2006
    • 148
    • Dickson, TN
    Granted the best method of prevention is control of the trapped piece, but on a cut like this, the use of a short fence (or a stop block on the stock fence) is probably the way I'd make it. Just my thoughts....
    Ken W.
    _____________________
    "If you can't fix it right, fix it so no one else can fix it right."
      Yeah, I don't think I would have made that cut in that manner. put the saw on wheels so that you can use your rip capacity. Well, even then it might be dodgy to cut across the 24" of a 24x48 in that manner.
      Certainly using a push stick to push the 1" through probably would have solved his issue, as he seems to have finished the cut ok, then left the 1" piece sitting between the fence and blade, I would never do that regardless of kickback pawls.
      • ragswl4
        • 1559
        • Winchester, Ca
        • C-Man 22114
        That cutting method is a 110% guarantee of a kickback on the piece between the fence and the blade. I gotta say "what was he/she thinking?" One way to control this type of kickback is with those yellow roller thingies that attach to the top of the fence and put downward pressure on the piece between the fence and the blade. However I don't think they work on such a narrow piece. I use them all the time, never a kickback. I have even tested them by releasing the piece between the fence and blade after its cut and they just hold the wood there. Try at your own risk. Great product for safety.
        RAGS
        Raggy and Me in San Felipe
        sigpic
        • Hoover
          • 1273
          • USA.
          The op on smc is trying to justify buying a new tool when it is do to operator error. Please, that person needs to take a safety training course, or else use better judgment.
          He is fortunate in that the flying missile didn't hit him or cause other injury.
          No good deed goes unpunished
