Yes, it's true. A woodworker can never have too many clamps. I'm looking for miter clamps. I'm doing more window casing (trim), and I'm thinking of using a method described in Fine Homebuilding. The method is to use biscuits in the miter joints. Has anyone done that? I'd like to cut, biscuit, glue, assemble, and clamp the miter joints, so I end up with a complete unit (like a picture frame) that can be nailed up to frame the window. Unfortunately, most miter clamps are designed to clamp your work at a "perfect 90 degrees," as if that's the desired angle. But life isn't always 90 degrees. Sometimes it's 89 or 91, and when you use one of those "perfect 90 degree" clamps, you end up with an open joint. Anyone have comments on clamps they've tried successfully, and even unsuccessfully?
Thanks,
Rick
P.S. I'd like to share a phrase, which I can relate to, I read on another forum. I laughed when I read it, and it makes perfect sense to me. Here it is:
"I suffer from CDO, which is like OCD but in alphabetical order, as it should be."
(OCD = Obsessive Compulsive Disorder) Just in case you were scratching your head on the acronym.
Thanks,
Rick
If it's stain grade it might be worth the effort you speak off.
