I am looking at the Steel City 60100 VS midi-lathe, thinking it looks like a great value from Tool King for $249.
In a FWW review, they found it took twice the pressure (15 lbs) to stall it at low speed as the PSI VS Turncrafter Pro.
When I looked at the Steel City specs, I saw something that I am hoping someone can shed some light on. Both the VS and the manual 5 speed version are rated at 1/2 HP continuous, but the VS draws 3 amps, compared to 5.6 Amps for the 5 speed. Why the difference? Is it just a difference between AC and DC motors? Does this affect the output torque?
60100 Mini Lathe Variable Speed
Continuous Duty 1/2 HP
Amps 3
Voltage 115V DC
Phase Single
Hertz 60 Hz
RPM 500-3800
60170 Mini Lathe 5-Speed
Continuous Duty HP 1/2 HP
Amps 5.6
Voltage 115V AC
Phase Single
Hertz 60 Hz
RPM 1725
Amps 3
Voltage 115V DC
Phase Single
Hertz 60 Hz
RPM 500-3800
Amps 5.6
Voltage 115V AC
Phase Single
Hertz 60 Hz
RPM 1725
