Jet Air Filter, AFS1000B Prefilter
  • Texas splinter
    • 211
    • Abilene, TX, USA.
    I have a Jet AFS1000B air filter hanging from the ceiling of my shop. It's been up there for almost two years, but only been used about 6 times. In fact, the shop was not used at all for over a year, while I was gone on contract.
    I looked at the "Electrostatic Filter" that is the pre-filter element, and it is totally covered in dust, rather thick dust. Does anyone know any way to clean this filter? I priced the replacements, and they are REALLY PROUD ($$$) of them. I thought about replacing it with a regular furnace filter, even the most expensive furnace filters are less than half the cost of the Jet element, but Jet made it 11 1/2" X 23 1/2" and I don't think the opening will take a 12 X 24 filter element.
    I guess I could buy a "cheapie" to try for fit, or I could just use the handyman's friend, duct tape and mount a new element on the outside of the lip of the filter body. The inner "sock" filters can be cleaned, I believe.
    "Aspire to inspire before you expire."
    Chuck Hershiser
    Abilene, Texas
  • cork58
    • 365
    • Wasilla, AK, USA.
    filter
    I have a Jet AFS1000B and have changed the filter many times over the past year. Don't know about you but love it to death. I have only cleaned the inner once and then didn't really need to. I use a HEPA that I get from Home Depot or Lowes. Mine will take a 12X24X1. It is a tight fit but maybe that is why the inner never gets dirty. Don't know but I do know you can use a "cheepy" filter, I do.
    Cork,
    • MikeMcCoy
      • Nov 2004
      • 790
      • Moncks Corner, SC, USA.
      • Delta Contractor Saw
      Another that uses filters from Lowes. Something else that helps is to attach another filter to the outside of the unit. A simple little "L" bracket works but Rockler has some plastic brackets that are made for the purpose.
      • sweensdv
        • 2873
        • WI
        • Baileigh TS-1040P-50
        Not sure if they are still available or not but the outer electrostatic filter that I have for mine is washable. I've had it for years and all I ever do when it gets dirty is rinse it out, let it dry for 24 hours and reinstall it. The Model number from Jet was/is 708708.
        EDIT: I found this at Amazon but the picture doesn't look like mine. Mine is metal mesh with some type of filter fabric sandwiched between the mesh layers. Maybe a call to Jet Customer Service could clarify what style the current model is.
        • Texas splinter
          • 211
          • Abilene, TX, USA.
          This is why I LOVE this forum! Thanks guys, I'll take a look at the Jet washable, but I am thinking that i may be able to get a 12 X24 X 1 washable furnace filter at Lowes or HD.
          Again, thanks a bunch, guys.
          Chuck Hershiser
          Abilene, Texas
