I bought this new almost 2 years ago but have used it only occaisionally. It was working great. I turned it off one day, turned it on the next and NOTHING. Of course its plugged in but when I turn it on it may as well be unplugged. Any quick/easy fix ideas? Is it worth trying to get the compressor repaired? Thanks for the help!
Makita MAC700 air compressor question
Not sue, but I don't think it uses the gauge. I think it has a sensor on the tank under the motor.
Perhaps you could get a parts list for the Makita from the Makita web site. Or call them and explain the symptoms and ask if the pressure switch could be shot. Maybe there would be a way to jumper it out to test it (with the tank drain valve open, of course).Comment
Is there by any chance a fuse somewhere that may have blown?Jon
techzibits.comComment
Not sure if you still have the manual but here is a link to the online version. It has a number of suggestions in the troubleshooting section for "motor wont run."
Good luck.
http://www.makita.com/assets_product...als/MAC700.pdfJon
